Connecting your Wallbox charger to equiwatt enables you to automatically participate in equivents and avoid charging when electricity is dirty and expensive.
If you own a Wallbox charger you can connect it to the equiwatt app by following the below steps:
Please note: You will need to have a smart meter that is sending half-hourly readings connected to your equiwatt account before you can connect your EV charger to the app.
Step 1: Add Charger
Open the ‘Manage’ tab of the equiwatt app and select ‘Add New Device’ > Select ‘Add Smart Charger’.
EQ App - Add Devices and Integrations
Step 2: Select Brand
Select the Wallbox EV charger.
Step 3: Sign in
To connect your device to equiwatt, you will need to select your Wallbox charger model and enter its serial number. You can also give your charge point a name.
Step 4: Successful Linking
Once you have signed in, your smart charger will be successfully connected to the equiwatt app, ready to participate automatically in events.
EQ App - EV Charger Settings Screen - Wallbox
