Follow the instructions below to set up your EV to participate in equivents.
Connect your electric vehicle (EV) to the equiwatt app by following the steps below:
1) Open the ‘Manage’ tab of the app and select ‘Add Electric vehicle’.
3) Follow the onscreen instructions to successfully connect your EV to your equiwatt account.
5) Once your EV is linked and your home location is set, you will be directed to allow your EV to participate in equivents toggle that is set by default as ON. *
PLEASE NOTE: You can opt-in or out of equivents participation at any time by switching the toggle on or off.
Your EV will be ready to participate if an equivent starts when:
  • Your EV is plugged in and charging
  • You are charging at home
