Once you have set up your Smart Plug in the Kasa Smart App and ensured that it is plugged in and connected to your home WiFi network, you are ready to add it to your equiwatt account!
PLEASE NOTE: Only the HS110 & KP115 Energy Monitoring smart plugs are compatible with the equiwatt app.
If you have other makes or models, these cannot currently be connected to automate participation via your Kasa account.
However, you may be able to automate your plug’s participation in equivents via our IFTTT integration. Learn more here
1) Log in to your equiwatt account via the equiwatt app.
2) Select the ‘Manage’ tab by selecting the toggle icon.
EQ app - home screen EV charging & Kasa plugs
3) Under the ‘Integrations’ widget, select ‘Add New Device’ and ‘TP-Link Kasa Plugs’.
11-2
4) Enter your Kasa account login credentials and select ‘Authorize’ to allow equiwatt to remotely control your Kasa devices so that they can participate in equivents.
New Kasa account log in
5) Your Kasa account has now been successfully linked to equiwatt. You can now select how long your Smart Plug(s) participate in equivents as well as if they participate at all.
Kasa plug - view command history
TIP: If you select ‘View Command History’ you will be able to see when equiwatt has sent a command to turn off or turn on your smart plug.
Kasa plug command history
6) Once you have made your selection, press the ‘arrow’ button at the top left of the page to return to the home screen.
7) Your Smart Plug(s) will now appear under the ‘Kasa Plugs’ widget on the home screen of the app.
PLEASE NOTE: When you add any additional compatible TP-Link smart plugs to your Kasa account, it will automatically sync with equiwatt and add the new plug to your account.
Click here to find out how to set up your Kasa account and connect your first Smart Plug.
