To connect your battery follow the steps below:
Step 1: App Setup
Before you can connect your battery, you will need to make sure that you have set up your equiwatt account by following the below steps:
Step 2: Connecting the Battery
  • Open the equiwatt app.
EQ App - Manage Tab
  • Open the ‘Manage’ tab (Toggle icon) of the equiwatt app.
EQ App - Add Devices and Integrations
  • Select ‘Add other integrations’ and press ‘Add Smart Battery’.
EQ App - Smart Battery
  • Press ‘Connect’.
EQ App - Select Battery Brand
  • Select ‘AlphaESS’ from the list and press ‘Connect’.
EQ App - Alpha login
  • Enter the Battery Serial Number and Battery Check Code when prompted.
EQ App - AlphaESS Battery Settings Screen
  • The app should now display the ‘Participation Controls’ screen, indicating the setup has been completed successfully.
EQ App - Home Screen - AlphaESS Battery connected - no event live
EQ App - Home Screen - AlphaESS Battery connected - widget - no event live
  • Your battery should also now appear on the home screen of the equiwatt app, with the current battery level and current charge visible via the widget.
