How do I opt into equiwatt’s DFS powerSmart events?
When you first create your equiwatt account, you will not be automatically opted in to take part in all our powerSmart events.
Instead, you will need to opt in by following the below instructions:
Open the equiwatt app > Go to the home screen.
Select the green button ‘You are eligible to participate in powerSmart events. Tap to learn more.’ button.
Confirm your wish to opt in via the pop-up screen that appears.
You will now be opted into all future powerSmart events.
Please note: You will need to confirm your participation in each event by opting in via the app to take part in the event and earn points.
You can check your opt in status for powerSmart events by opening the home screen of the app and checking the colour of the bar that appears. If you are opted in then the bar will be yellow. If you are not opted in then the bar will be green.
If you are successfully opted in then the text on the bar will also read as follows: ‘You’re opted in to participate in powerSmart events. Tap to learn more.’
