If you have moved house and want to update your address please follow the steps below.
As your address is pulled automatically from your smart meter, the quickest and easiest way to update your address is to remove your old smart meter from your account before adding your new smart meter.
Remove your old smart meter
You will need to remove your old smart meter from your account to automatically update your address and ensure you don’t miss out on participating in equivents.
To disconnect your smart meter from the app, please follow the instructions below:
1) Go to the ‘Manage’ tab of the app and select ‘Smart Meter’
EQ App refresh - Manage tab - sm connected & address verified
2) Select the cog icon in the top right-hand corner
EQ App Refresh - Smart Meter Stats Screen
3) Select ‘Remove MPAN’
EQ App refresh - Meter Settings Page
4) Select the red ‘Remove MPAN’ button to confirm
EQ App Refresh - Disconnect Smart Meter Screen
Your old Smart Meter has now been removed and you can now add your new Smart Meter by following the steps here
