We will always connect to your EV via software supported by your EV’s manufacturer.
You will be asked if you wish to connect your EV when setting up your car in the equiwatt app. From there, you will be redirected to a secure login portal for you to enter your vehicle’s login credentials (the same as you use for your connected car app - see the example below).
We will find your EV and ask for your permission to access your car. equiwatt will always use manufacturer-supported software to securely connect to your car.
5-Sep-04-2024-08-00-07-8589-AM
