Your IHD is a small digital display that connects with your smart meter tos how your home’s live energy usage data.
IHD
An in-home display is a small digital display that links to your smart meter and shows your home’s live energy usage data.
You should have been given one when your smart meter was installed.
As part of our sign-up process, you can use some information obtained from this display unit as a way of verifying your right to access energy data from that smart meter.
You can find out more about how to connect your smart meter to the equiwatt app here.
Please note: If your display no longer works, you will still be able to connect your smart meter by entering the MAC/GUID/EUI number printed on theside or bottom of the display or by using one of the other verification methods highlighted in the app.
